auto conversion
Old Jul 20, 2008 | 06:50 PM
06blueovalblueGT's Avatar
06blueovalblueGT
Default RE: auto conversion
Just do what i'm doing,..give the wife the '06,
< I can still hear her saying "Order it the way you want, It's YOUR hot-rod" >
And let the search begin for the "70 Mach-1,
That I should have bought in the first place
Old Jul 20, 2008 | 09:17 PM
StantheMan's Avatar
StantheMan
I did a transmission swap on a 71 Charger. Some of the things that you will have to do, is change the flywheel, pedals, hydraulic cylinder, linkage from cylinder to throwout bearing, pressure plate, clutch, shifter, and if the is any variance between the length of the standard transmission compared to the auto you might even need a drive shaft. I agree with the majority, most likely not worth the trouble.
Old Jul 21, 2008 | 08:27 AM
ShelbyDoc's Avatar
ShelbyDoc
It can be done for $2300 if you install yourself. That is everything you need shipped.
fastbackford351
Oct 1, 2015 12:24 PM
mungodrums
Sep 28, 2015 10:54 PM
wraith777
Sep 28, 2015 10:49 AM
Sixer4Life
Sep 28, 2015 07:05 AM
2poor4u2
Sep 26, 2015 11:08 AM
