Fog Lights - Do they make a difference?
Old Sep 11, 2008 | 09:31 PM
  #31
Lifter583's Avatar
Lifter583
Thank you Wheelman! I will look into setting those relays up.
Old Sep 12, 2008 | 09:07 AM
  #32
157dB's Avatar
157dB
Cut & Paste Expert
You will want these:
http://iihs.net/fsm/?dir=40&viewfile...0Autolamps.pdf
http://iihs.net/fsm/?dir=40&viewfile=Fog%20Lamps.pdf
Old Oct 7, 2008 | 09:32 PM
  #33
Jasoon's Avatar
Jasoon
Wow, a lot of replies.
So, I was thinking to get a v6 pony package fog light kit and to put fog lights somewhere in the lower bumper/grill area, either split or together where the licence plate isn't...
Or are the pony package foglights too big in diameter to even try to fit/mold them into the grill
Anyone seen or done anything like this that came out looking nice?
Here's a quick photochop of what I was thinking.
Old Oct 7, 2008 | 10:55 PM
  #34
1morepart's Avatar
1morepart
i deleted my factory gt fog lights by puting on a cervini grille.......now, no one bright lights me on the highway anymore. i don't miss them
Old Oct 8, 2008 | 06:46 AM
  #35
Nuke's Avatar
Nuke
As I implied earlier, whatever you install, be sure the reflectors are a fog pattern and not a driving pattern (assuming you're truly looking for improving driveability in dark, foggy conditions). Also, the type of bulb plays a huge difference. Brighter is NOT better; nor is cooler. You want to stick with standard wattage (typically 55 watts) and cooler (yellow) cooler. All the posts above that suggest brighter and cooler bulbs are the ones that probably use their fogs as driving lights and **** the rest of us off.
Diode Dynamics
28
May 26, 2022 12:02 PM
ak98
Sep 10, 2015 10:33 PM
MustangHead91
Aug 23, 2015 09:37 PM
inyadreems
Aug 21, 2015 09:10 AM
dseg
Aug 8, 2015 09:00 PM
