Programming a Flip Key
Old Jul 16, 2010 | 01:46 PM
  #41
09cs's Avatar
09cs
Originally Posted by AJ_68
Nothing really, it just flips out Chuck Norris style (and looks more high tech)
And you don't have the end of the key poking and stabbing your leg when it's in your pocket lol.
Old Jul 16, 2010 | 02:06 PM
  #42
157dB's Avatar
157dB
Cut & Paste Expert
07 and up only, guys.
Key Programming — Additional Key With One Programmed Key
NOTE: This procedure is used when a customer needs to have an additional key programmed into the vehicle without erasing stored key codes, but does not have 2 programmed keys available. This procedure is also useful when attempting to determine if an ignition key is defective, as a new key can be installed without erasing keys or without having 2 programmed keys available.
the only way to program another key with just 1 key is by plugging it in to the Worldwide Diagnostic System computer and reprogramming, this way it will not erase the code to your hidden key.
Key Programming — Program a Key Using Two Programmed Keys
if you have to programmed keys available then you can program additional keys without taking it to the dealer.
NOTE: This procedure works only if 2 or more programmed ignition keys are available and additional programmed key(s) are desired.
if you can find your hidden key you can program additional keys yourself and save about $110.00 for programming which is what our service department charges.
Insert a programmed ignition key into the ignition lock cylinder and turn the ignition switch from the OFF position to the RUN position (maintain the ignition switch in the RUN position for 3 seconds, but not longer than 10 seconds).
Turn the ignition switch to the OFF position and remove the first key from the ignition lock cylinder.
Within 10 seconds of turning the ignition switch to the OFF position, insert a second programmed ignition key into the ignition lock cylinder and turn the ignition switch from the OFF position to the RUN position (maintain the ignition switch in the RUN position for 3 seconds, but not longer than 10 seconds).
Turn the ignition switch to the OFF position and remove the second key from the ignition lock cylinder.
Within 20 seconds of turning the ignition switch to the OFF position, insert the unprogrammed ignition key (new key) into the ignition lock cylinder and turn the ignition switch from the OFF position to the RUN position (attempt to start the vehicle).
If additional programmed key(s) are desired, repeat the key programming procedure.
Old Jul 16, 2010 | 07:15 PM
  #43
R1nStang's Avatar
R1nStang
what do you mean by the "hidden key"
Old Aug 10, 2010 | 05:45 PM
  #44
jolaechea's Avatar
jolaechea
Hi, every body, anyone know where is located the cylinder key to open the trunk, i cant find it ??
Old Aug 26, 2010 | 02:14 AM
  #45
RA042426's Avatar
RA042426
Banned
Hi guys/gals I ordered mine tonight, I'm thinking about paying a autolocksmith to cut mine. Thanks for all the information you guys provided.
Old Aug 28, 2010 | 03:39 PM
  #46
157dB's Avatar
157dB
Cut & Paste Expert
Of the two keys you received when you purchased the stang, the 'hidden key'
is the one you hopefully hid somewhere safe for when you want to program
more PATS keys to your S197 stang.
File Type: pdf
lincolnshibuya
Dec 8, 2015 04:37 PM
logan409
Sep 26, 2015 07:43 PM
jessicarabbit
Sep 25, 2015 12:41 PM
Beerman309
Sep 19, 2015 01:16 AM
Sep 8, 2015 11:50 AM
