Whipple ordered!
One other thing...did you guys use the entire bottle of s/c oil that they give you? I'm having a hard time seeing the oil level through the sight glass. Can't tell if the oil is at the middle mark.
Yes. It's premeasured. The sight glass will be above halfway but will come down when the motor is running.
i bucked the trend and went maverick on that one. after looking at all
the possibilities i ended up placing a fuel pressure sender in the fuel
line that runs between the rails. pic is available upon request, but it
gets installed on the passenger side near the rail.
now that the aeroforce is available, i think most just rely on that
for fuel pressure readings.
had the FP sender installed on the passenger side using a N20 t-fitting bc thats what was available at the time.
