Help! Can't remove harmonic balancer!
Old Jun 10, 2010 | 08:15 PM
  #21
Casey4s's Avatar
Casey4s
Originally Posted by jahudso2
Well I think I figured out what happened. I pulled the pulley on fully, but I think I damaged the first couple mm of threads on the crankshaft using the pulley remover tool. Therefore, the stock bolt isn't quite long enough to reach the threads which are still intact. I'm going to buy a couple of longer bolts tomorrow and some washers to try to get the spacing correct. Hopefully that will solve this problem.
If you get it pulled into place the stock bolt will work. A longer bolt can bottom out and cause you problems. If you use a longer bolt and stack washers to get the pulley far enough on to get the Ford bolt to work.
You can't use just any hardness of bolt here from a hardware store or NAPA.
Have you read this "how to"?
http://forums.themustangsource.com/f...l-pics-452799/
I think it might give you some insight.
I hope this turns out OK for you.
EDIT:
Here's another one.
http://www.americanmuscle.com/steeda...y-install.html
Old Jun 10, 2010 | 09:02 PM
  #22
jahudso2's Avatar
jahudso2
Yeah I've read the how-to's, but none of them seemed to mention that you can't run the tool straight into the crankshaft.
Do you think an 8.8 would be a high enough grade to hold the crank pulley? I know the stock one is 10.9, but I'm not sure I'll be able to find a 10.9 with the 1.5 thread pitch. Most of the 10.9s are 1.75 thread unfortunately.
BOB ROME
Jul 26, 2023 01:54 PM
jwog666
Dec 27, 2021 08:09 PM
Dathan
Oct 5, 2015 05:52 AM
jrrhd73must
Oct 2, 2015 09:17 PM
LivingInThePast
Sep 16, 2015 12:20 PM
