hey i was just wondering everything that needs to be changed when installing a new cam even one that says i can use stock springs what other parts would i need and also any reviews on the http://www.brenspeed.com/127050.html comp cam all help is very much appreciated thank you
i just did my cams and i replaced my timing guides, timing chains, and i needed adjustable cam sprockets. if your on a buget you can deffinitly get away without replaces those, but comp cams is saying will work with stock springs and as long as you don't have high mileage on the car you should be good.
