3.7L V6 Technical Discussions Any questions about the new engine, transmission, exhaust, tuners/CAI, or gearing can be asked here!
Twin Charging the 3.7
Old 08-27-2018, 03:59 PM
maxw1229
maxw1229's Avatar
Default Twin Charging the 3.7
Ok, so I know this project is crazy, not at all practical, and very expensive. I'm perfectly fine with that. I have a 2012 3.7L mustang that I will modify after getting my second car. I thought about engine swapping before but I decided to stay true to its v6 roots. That being said I have been very intrigued by the idea of adding both a supercharger and a turbo to it. There is a kit in the works for the gt500 blower to be fitted to the 3.7L (I'm getting a raised aftermarket hood so clearance isn't an issue) that I will be using and the turbo is undecided. I wanted to ask if any one is familiar with the twincharging process and what supporting mods will be needed? I plan on starting this project in about a year so I'm in no rush. Thanks in advance!
maxw1229 is offline
Old 08-27-2018, 05:00 PM
08'MustangDude
Banned
08'MustangDude's Avatar
You have to use a small supercharger. That feeds boost into the engine as the large turbo spools.
When the turbo is producing boost, the supercharger is bypassed and decoupled to reduce parasitic
loss. That means a lot of efficient power; with near-instant response; and a long, flat torque curve.
This is for smaller motors, not sure how effective it's going to be on a bigger V6. This has been
around since 1985, with a Lancia Delta car, and 1989 with a Nissan. Volkswagen has been
twincharging their 1.4 TSI in Europe. VW claims it has an output to a naturally aspirated 2.3-liter
motor, but with 20% better fuel economy. However, they're done with that because:
VW engineers now believe that new turbocharging technology can achieve similar results at a much-reduced cost.
Putting that GT500 blower on your 3.7 is way too big for the twincharging setup. You may as well
just use the blower by itself. Twincharging is engineered for small displacement motors.
08'MustangDude is offline
Greer
3.7L V6 S550 Tech 2015 - 2017
01-24-2019 01:00 PM
MadMax90
05-13-2015 10:28 PM
Elspa
06-03-2010 09:02 PM
Avalanch3
02-17-2009 08:13 AM
Obsol3te
11-10-2004 02:41 AM
Quick Reply: Twin Charging the 3.7
