Having a problem.
Old Apr 26, 2007 | 05:25 PM
breagles's Avatar
breagles
Default RE: Having a problem.
Check your fuel pressure . I had the same problem with mine . it might be a weak pump . mine still worked but would bog and pop upon accelleration or under a load . be careful because running lean causes detonation and detonation causes you to have to get a new motor . Good luck
Old Apr 26, 2007 | 05:30 PM
OzzDOA's Avatar
OzzDOA
+1 for the fuel filteror pump or both.
Old Apr 26, 2007 | 06:15 PM
CoolAid's Avatar
CoolAid
Wouldn't hurt to dump some fuel injector / fuel system cleaner in the tank while your at it.
Old Apr 26, 2007 | 06:43 PM
rainydayracing's Avatar
rainydayracing
ORIGINAL: SpartanStang
ORIGINAL: LX90
It boggs whenever it hits WOT, if I gradually excellerate, it runs fine. It idles fine, but if it I floor it (hit WOT) It boggs and drags till I let off.
My tempo did that for a while when it was kinda cold out. I had to shut off the car, and start it again. If that didnt work i had to shut it off, disconnect the battery for a bit, then reconnect and try again. Still dunno what the problem was, but it doesnt do it anymore. [&:]
I did like the monkey stang, but prefer the new stripper stang. Too bad you can't get an image of Neil Patrick Harris snorting a line off of a strippers a$$ from Harold and Kumar....lol
Old Apr 27, 2007 | 08:50 PM
LX90's Avatar
LX90
ORIGINAL: OzzDOA
It was the fuel filter, I changed it yesterday, and the car is like new again. Thanks for the thoughts, helped me work my brain.
Vrooom
Feb 21, 2016 05:25 PM
69Volunteer
Sep 30, 2015 10:39 AM
bconboy
Sep 24, 2015 01:55 PM
mdj89
Sep 23, 2015 08:49 AM
ccdguy
Sep 19, 2015 05:20 PM
