runing a cooler thermostat?
I have a 04 GT that is closin in on 50k miles and i am going to change the coolant but my question is should i put a cooler thermostat in? if so which one and are they even worth puttin in over the stock stat? any advice would be appreciated thanks
RE: runing a cooler thermostat?
I would, also use a programer to have your fans come on at a lower temp.
If you go below 160 degree's then you will throw a CEL on a cold day because there is a heat timer to get up to that degree level. At least thats how it is for the V6, its probably the same for the GT.
I think 180 is a good t-stat to use, now thats for a V6.
ORIGINAL: PaintballFreak
there is another thread for this, just search thermostat in 4.6 tech
they were saying to go wtih 180 and 160 was too low
No real performance gains from a cooler T-stat. YOu really want to try something use distilled water with Redlines' Waterwetter. That'll make everything cooler and dissapate heat more evenly and rapid. Never any debate with WW, stuff just works!
jwog666
12-27-2021 08:09 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
