PP Tb/Plenum
Old 01-15-2008, 06:27 PM
MineralGrey
MineralGrey's Avatar
Default RE: PP Tb/Plenum
ORIGINAL: ThisIsMyStang
Mine was really tight! Had to use drill bit channelocks and lube! But is all good now! Another heads up when you are installing, on the the Throttle positioning sensor the phillips screws can be tough to get out and they strip easy so be patient and careful cause its plastic and can break.1 of the2 screws came right out and the last one took some cussing but it came out. Good Luck!
+1 I forgot about that mine were both stripped so I took a hand saw blade and turned them into flat head screws
MineralGrey is offline
Old 01-15-2008, 07:28 PM
I G Joe
I G Joe's Avatar
i just used some plyers and got it in there, works great.
I G Joe is offline
Aereon
11-21-2006 04:04 PM
leglocking101
11-15-2006 01:22 AM
mustangj23
11-11-2006 05:19 PM
40thGT
09-07-2006 07:41 PM
hawwk11
02-26-2006 06:06 PM
Quick Reply: PP Tb/Plenum
