NEW BBK 78mm Throttle Intake
Old Jun 28, 2008 | 07:12 PM
  #21
Jbauer's Avatar
Jbauer
Default RE: NEW BBK 78mm Throttle Intake
i agree. I bet there are going to be lots of reports of those valves going south
Old Jun 28, 2008 | 11:04 PM
  #22
Sxynerd's Avatar
Sxynerd
Anything that increases CFM volume flow will help increase power and throttle response. Throttle R will be most of what you notice till you either get it tuned or you add your blower. NA I made 261-265 (dyno depending) with only weld in flows,TB/Plen, O/R H, and a tune. It's like the old Garbage in Garbage out, more air equals more power. Then you're limited by the CFM volume of the heads and manifolds. Like the few have said before, if you have a stock system then that would be a great buy but if you already have an after market, then I don't think it wold be worth it unless you're going for aesthetics.
Hope we've helped.
Old Jun 29, 2008 | 12:25 AM
  #23
Xemeth's Avatar
Xemeth
ORIGINAL: Warrior62
I have never seen or heard ofthis until today, figured some of you haven't either. Seems like the best bang for the buck, and gives some more airflow for those of us with a little more boost than the standard 8-10 psi. Plus, it flaunts the SOHC! LOL. At least its cheaper to buy just one cam than two...
"Another Design and Patented Performance first from BBK Performance – This all new BBK 78mm throttle intake incorporates a high flow intake plenum and a larger 78mm BBK throttle body all in one great performing unit.
Add 12-15 horsepower with this direct bolt-on.
This patent pending design has all the quality features you would expect from a BBK product - built from lightweight 356 aluminum castings this kit comes complete with all necessary hardware and horsepower!"
Just cought this, but 2v's have two cams. You'd be in trouble if you only bought one.
Old Jun 29, 2008 | 12:56 AM
  #24
defconfire's Avatar
defconfire
I think he may have ment 1 cam per bank.... vs the 4v's
Old Jun 29, 2008 | 11:40 AM
  #25
bb816331's Avatar
bb816331
I ♥ Acer
So does anyone know of a place that actually has these things in stock? I've been lookin at one for my new stang.
Old Jun 29, 2008 | 11:53 AM
  #26
black35th's Avatar
black35th
Have you tried Summit Racing?
Jb145700
Aug 21, 2022 06:37 AM
Luke9222
Oct 22, 2015 11:55 PM
JDWalton
Sep 24, 2015 08:47 PM
12bigredstang
Sep 24, 2015 10:43 AM
Sep 8, 2015 11:50 AM
