2003 GT Mustang 4.6 Anti-Slosh Module
I can't find any info on where, or if, there is an anti-slosh module designed into the dash cluster of a 2003 GT Mustang with a 4.6 SOHC engine. I have posted two pictures here. The 1st picture, is actually from a 1998 Cobra which shows the dash cluster with the anti-slosh module which snaps into the lower right hand side of back of the dash cluster. The 2nd picture, is a dash cluster, from a 2003 GT Mustang with 4.6 engine. It does not appear to have an anti-slosh module installed anywhere on it, at least not that I know of. If anyone has any info, or can share pictures with the rest of us, it would be greatly appreciated. Thank you for your support, Tommy.
Ok, for those who may be interested, this is what I was looking for:
The 2003 mustang doesnt have a replaceable Anti-Slosh module, it is incorporated into the workings of the instrument cluster, the cluster is a programable module that has to be programed to the car to operate properly, this is from the service manual.
Fuel Gauge
NOTE: It is critical to follow the pinpoint test diagnostic methods to make sure the correct mode is being used during diagnostics.
The instrument cluster receives the fuel level signal from the fuel level sensor, part of the fuel pump module. The fuel level sensor measures variable resistance in the fuel tank depending on the current fuel level. When the fuel level is low, the resistance in the unit is low (15 ohms ± 2 ohms). When the fuel level is high, the resistance in the unit is high (160 ohms ± 4 ohms).
The instrument cluster uses 4 different operating modes to calculate the fuel level:
key OFF fueling
anti-slosh (default mode)
key ON fueling
recovery
After a fuel fill up, the time for the fuel gauge to move from empty (E) to full (F) ranges from 2 seconds to 55 minutes depending on which operating mode the fuel gauge is in.
The key OFF fueling mode (2 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The key must be in the OFF position when refueling the vehicle.
At least 15 percent of the vehicle's fuel capacity must be added to the fuel tank.
The instrument cluster must receive a valid key ON fuel sender reading within 1 second of the key being put into the RUN position. The key ON sample readings are considered valid if the fuel sender reading is between 15 ohms ± 2 ohms and 160 ohms ± 4 ohms. If these conditions are not met, the fuel gauge stays in the anti-slosh mode, which results in a slow to read full (F) event.
The default fuel gauge mode is called the anti-slosh mode. To prevent fuel gauge changes from fuel slosh (gauge instability due to changes in fuel sender readings caused by fuel moving around in the tank), the fuel gauge takes approximately 55 minutes to go from full (F) to empty (E).
The key ON fueling mode (approximately 90 seconds to read empty [E] to full [F]) requires 3 conditions be met:
The transmission is in park (P) (automatic transmissions), or the parking brake applied (manual transmissions).
The key is in the RUN position.
In key ON fueling mode, a 30 second timer activates after the transmission is put into the park (P) position (automatic transmissions) or when the parking brake is applied (manual transmissions). When the 30 second time has elapsed and at least 15 percent of the vehicle's fuel capacity has been added, the fuel gauge response time is 90 seconds to read from empty (E) to full (F). When the transmission is shifted out of park (P) or the parking brake is released, the fuel gauge strategy reverts to the anti-slosh mode. This mode prevents slow to read full events from happening if the customer refuels the vehicle with the key in the RUN position.
Recovery mode is incorporated into the instrument cluster strategy to recover from a missing fuel level message during a refueling event. Missing fuel level messages result from intermittent opens in the fuel sender or its circuits. Recovery mode (empty [E] to full [F] approximately 20 minutes) is initiated when the following 2 conditions are met:
The instrument cluster is in the anti-slosh (default) mode.
The actual fuel level in the tank is greater than what is being displayed by the fuel gauge.
Fuel Gauge
key OFF fueling
key ON fueling
recovery
SANDY21
08-17-2015 02:41 PM
'stangdude
08-12-2015 01:27 PM
