2.6 KB install on 2v questions...
Next week I will be installing :
Just curious on what HP numbers yall think i would get...
Also what install problems might I have??
Thanks , I just want to make sure this can all be done right next weekend and not run into any problems where i have to special order a part..\
Ryan
- Built motor 8.5:1 Compression
- 03 Cobra tank/Dual Walbro pumps
- Upgrade FPDM (still have to research this)
- KB 2.6 has 3.3" RR 8 rib pulley on it
- Meziere Elec Water Pump
- Battery box Intercooler tank
- Large Heat exchager
- Stock heads comp stg II n/a cams
- KB 40amp BAP
- Cobra Throttle cable
- Cobra cruise control cable
- Is the EGR Setup different? Need a EGR Delete?
- What belt will i need with the 3.3 pulley?
Ryan
CP forged gas ported 19cc dished pistons
Manley forged H-beam rods
Cobra crank
Eventually i will Get new heads/ Cams... As for now I was everything in the car running right.. I am more into AUto X.. so dont really NEED alot of HP... I wouldnt mind 600whp in the future, but would definitely have to have two tunes.....
Yea i mean you don't need it for autox. Im gonna be using -11cc pistons w/ TFS 44cc heads to give a "stock" compression since im not gonna be boosting my motor for a while. So i'll be lookin into the same setup here in a few years.
Good luck w/ everything. Let us know the numbers!
89gtsleeper
09-29-2006 04:26 PM
