Struts or wheel alignment
Old Feb 22, 2011 | 12:43 PM
EODMustang's Avatar
EODMustang
Caster-camber plates are going to be the bare minimum of what you need with your car lowered if you are going to retain the stock suspension geometry. A bumpsteer kit (adjustable tie-rod ends), and taller ball-joints like the Steeda X2s should do that if I'm not mistaken. The taller ball-joint will push the end of the a-arms down one inch relative to the spindles, so they are parallel with the ground again. I have a bumpsteer kit, cc plates, and offset rack bushings installed, and even with the car pefectly aligned, the suspension geometry is still off. I bought the Steeda X2s, billet offset rack bushings, and HD sway-bar end-links, but haven't had a chance to install them yet. I'm fairly sure that when I do, and get the car aligned, it should be back to correct suspension geometry for the first time since I lowered the car.
Old Feb 22, 2011 | 12:53 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Originally Posted by deviousgt
Should I install camber plates? If I need to adjust the camber setting would camber bolts be ok?
FWIW--my opinion of camber bolts...
Old Feb 22, 2011 | 01:03 PM
EODMustang's Avatar
EODMustang
Looking back, if I had known more about suspension before I started modding mine and lowering the car, I would probably just have gone with drop spindles. He's right, it really is the easiest way. There's nothing wrong with going the other route, it basically just comes down to preference.
Old Feb 22, 2011 | 03:00 PM
deviousgt's Avatar
deviousgt
So then what part do you suggest I get to fix my problem? The drop was 1.5 inches at most.
Old Feb 22, 2011 | 03:05 PM
deviousgt's Avatar
deviousgt
I ask this because being that I am a college student and only 20 years old I don't have much of a budget for my car at the moment but I don't wanna buy new tires that are gonna wear this way. Thanks for the input guys
Old Feb 22, 2011 | 04:47 PM
945LSTANG's Avatar
945LSTANG
I've always believed in installing c/c plates regardless of how much lower you're going.
Old Feb 23, 2011 | 11:21 AM
deviousgt's Avatar
deviousgt
If I buy the cc plates and install them will I need to get my car realigned?
Old Feb 23, 2011 | 07:37 PM
945LSTANG's Avatar
945LSTANG
Most likely, yes.
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
