Overheating Problem help!
Old May 11, 2011 | 08:15 PM
bronxbomerss2's Avatar
bronxbomerss2
my pops says its the radiator says the smoke is coming from there and that its all wet in the middle so he says that it, does that sound right?
Old May 12, 2011 | 03:15 AM
zeus86's Avatar
zeus86
sounds like that could be it like said befor hope it's not the intake ford used all plastic on there intakes and i had just replaced mine it craked on the very front of the intake on the underside of it. if it was leaking there you would see a pool of cooland on the top of the block underneth the intake aswell
Old May 12, 2011 | 05:28 AM
uberstang1's Avatar
uberstang1
Chupacabra
Radiator and intake are easy to change, like cliffy said I'd rather be changing an intake manifold than a head/head gasket.
Old May 12, 2011 | 02:13 PM
bronxbomerss2
no deff. not the intake and i didn't find any coolant leaking around the car either thats the thing, and the needle on temp guage never moved from the middle when it got there, so i don't think its the water pump, i changed the thermostat just to be safe so im gona take the radiator to a shop and have them pressure test it nd make sure its the radiator
Old May 12, 2011 | 07:23 PM
bronxbomerss2
ok well the radiator checked out fine, im starting to get worried i don't know what it could be the radiator is fine and the thermostat is new all the hoses are fine and the ac is fine and there isn't anymore smoke but the radiator fan isn't sounding proper and the car is starting to overheat now at least the guage is moving more towards the H now, so any ideas guys? any help is much appreciated
Old May 12, 2011 | 09:23 PM
bronxbomerss2
ok so i changed the oil since idk when the last oil change was done by the previous owner so i did it since the oil on the dipstick was low so figured that couldn't hurt so no more smoking whatsoever but the engine is still over heating after about idk 10 min of idling it was fine right in the middle but when i started to make it idle around 3k rpm it started to make the needle move over to the H side, my only conclusion would be the radiator ran bc its making a rele nasty sound like something is hitting it but would that cause the engine to run hotter??
Old May 14, 2011 | 01:03 AM
bronxbomerss2
any suggestions to what else it could be besides the fan? would the fan malfunctioning cause the engine to fun hot? or effect it that much i should ask? thanks guys
mungodrums
Sep 29, 2015 09:18 PM
stangin1996gt
Sep 21, 2015 11:01 AM
yourmom6990
Sep 14, 2015 10:52 PM
MusicCity615
Sep 12, 2015 07:05 AM
96stang3.8
Sep 10, 2015 06:42 AM
