Splitfire Sparkplugs
Old Jan 17, 2006 | 03:45 PM
code3GT's Avatar
code3GT
Mustang Nazi
Default RE: Splitfire Sparkplugs
I have found NGK's to be some of the best.
Old Jan 17, 2006 | 05:13 PM
blackbetty01's Avatar
blackbetty01
Thanks for the useful posts, I think I am going to pick up some NGK Iridium IXs this weekend. Hopefully I will have better luck this time. I only bought the Splitfires because a guy I know had a lightning and sold it before he put these in so he sold them to me for $20. I figured they would be an improvemnet over the stock plugs, but that obviously hasn't been the case. I would say from this experience Splitfires are crap.
Old Jan 17, 2006 | 08:33 PM
Deannostang's Avatar
Deannostang
I use the "V" plugs and they seem to run fine. Just have to replace them more regularly as they don't have the longevity some of the other more specialty plugs have. Double platinum's are also very good. Many manufacturers offer such a plug. Only negative thing I have really heard in the plug area is not to use Bosch Platinums as they don't seem to run well in Mustangs. Don't ask me why but I have heard this in many different forums. I have also heard such plugs as the "iridium" type are a waste of money unless you are at least pushing around the power of a '03 or '04 Cobra, or have some sort of forced induction. For two totally newly designed plugs on the market today, try the following links. Pretty interesting stuff!
www.zex.com
www.e3sparkplugs.com
Old Jan 17, 2006 | 09:19 PM
99REDGT's Avatar
99REDGT
NGK is the way to go...If you call them they will set you up as a dealer so you can order direct...they will even send you a catalog. i go through alot of them with the quad, fiddy, and go kart.
Old Jan 17, 2006 | 10:54 PM
MCFAST's Avatar
MCFAST
AUTOLITE XP 104 IRIDIUM, THE BEST!!!!!
Old Jan 17, 2006 | 11:10 PM
96cobra10101's Avatar
96cobra10101
Split fires are junk. Motorcrafts are inexpensive and work well in fords. Change them every 10K miles and you should be gtg.
GiddiupStang
13
Jul 6, 2006 06:46 PM
6mustang6
Apr 7, 2006 11:48 PM
98stang6
Mar 9, 2006 01:40 AM
99mustanggt
Oct 21, 2005 06:28 PM
ZEXEY02
Aug 3, 2004 06:14 PM
