Homemade mil elim ?
i got the car from my brother and he cut the wire and all didnt even leave the plugs lmao he is a DA. There is enough to splice onto with new plugs but he had straight pipe welded in with a h so there are no holes for the missing o2's can i get them tuned out would thay be better than trying to buy a harness and o2's and making elims whats the best route im sure i need a tune but ill have my n20 this weekend dont wanna advance the timing any but im sure they can tune wthout advancing the timing.
Anyway...So currently you just have wires hanging under the vehicle with now harness for the o2 sensor?
Get the car running correctly before you spray. As far as not having holes to plug the O2 sensors in, well that will be a problem when you're trying to make your own or when you buy MIL eliminators. I made my own, and had to physically cut through the original o2 sensor wires.
In my 98 I originally bought the Comp 270's, but couldn't get them to clear. I was running a stock NPI short block, PI heads, and the Comp 270's. Maybe your luck could be better than mine, but I had PTV clearance issues.
trashxtrash
09-20-2015 10:49 PM
