Buying the AFR 165's 3 quick questions
#21
RE: Buying the AFR 165's 3 quick questions
I'm not for sure, but I've always been told that if the duration is under 230 then clearance isn't as big of a factor. The stage 1 is 221/225, so if the above is true, it wouldn't be a problem....but, like I said, that's what I've been told, so take it for what it's worth.
#22
i plan on upgrading the springs when i get the AFR heads, but i wanted to use a cam like the TFS stage 1 w/ my 1.7 rockers but that puts the lift on the exhaust valve up to about .548, so I dont know if I should even try it. My friend is running .535 no problem...
#23
well afr broke it down for,about agreessive ramps rates,and how duration effects the outcome of your lift values....i got a big headache after that phone call/
ORIGINAL: gspfunk
#24
if you need help let me know.
ORIGINAL: OnyxCobra
Luke9222
10-22-2015 11:55 PM
