help i run too slow
RE: help i run too slow
lol if i had 3g's i would get me a block clean it up and by some nice heads and build me a motor! 12's for sure and then take old one out and as you get money you can clean it up or sell?
i would get the bbk exhaust i went to summit.com and got the bbk 1 5/8 headers and bbk o/r/ h-pipe that is with no cats, and i bought the american thunder catbacks by flowmaster and my car sounds damn good and can breath for that set up it is like 650 and they don't charge shipping!
my suggestion would be to get som flowmasters or bassani exhaust system strap on a supercharger or get some nos, maybe som eunderdrive pulleys,shift kit, get a nice tune up and you could do alot more but that could get a little exspensive, hope i was of some help.
lighten up the car 100 pounds..so pull out all that unwanted ****
pullies
14 degrees timing
3:73 gears
75mm maf
1/2 intake spacer
2.5 exhaust
syth oils
alum driveshaft
put the battery in the trunk
sticky drag radials et streets
lighten wheels
75 NX shot of nitrous
13's easy
pullies
14 degrees timing
3:73 gears
75mm maf
1/2 intake spacer
2.5 exhaust
syth oils
alum driveshaft
lighten wheels
13's easy
lol man what the heck ? put battery in trunk? he wants to go faster not traction? it would help if you was tryin to get in the 10's and was running a 11.10. all ya need to do is bbk exhaust, 373's, take the smog pump and stuff off, pullies, (but not altenator pullies), cold air intake, good tune up and wires, and drag radials and if you have a 5spd you in the 13's!
