Snapped bolt on bellhousing
So I am trying to put a new clutch in, everything was going pretty good until I snapped a bolt on the bellhousing. Its the small bolt on the bottom on the front side.
Also the top two bolts on the bellhousing, the one on the drivers side is there a bolt right next to it on the front side?
RE: Snapped bolt on bellhousing
Can you post some pics of the bolts? With the one on the bottom, heat the bellhousing around the bolt, and if there is any part of the bolt sticking out grab it with some vise grips VERY tight and try to crank it. As for the top ones, you might have to pull the trans back out.
-P.
-P.
maestro1024
09-21-2015 02:40 PM
