Fuel Pressure Regulator Suggestions
Old 09-22-2006, 01:08 PM
grumpyphillips
grumpyphillips's Avatar
Default Fuel Pressure Regulator Suggestions
Thanks to everyone who helped out yesterday with suggestions on what size fuel pump to get. I decided to go with Summit Racing's 155 lph. Now, I need to get a Fuel Pressure Regulator and I wanted to see if anyone had any suggestions on which one to get.
Thanks.
grumpyphillips is offline
Old 09-22-2006, 01:12 PM
88BlueGT
88BlueGT's Avatar
Default RE: Fuel Pressure Regulator Suggestions
Holly, Aeromotive, etc.
I had a BBK and it worked perfect but I have heard about people having problems with them not being accurate n stuff. Dont forget to buy a gauge too
88BlueGT is offline
Old 09-22-2006, 01:20 PM
grumpyphillips
You have to buy a gauge when you buy a Fuel Pressure Regulator? What kind of gauge do I buy?
Old 09-22-2006, 01:23 PM
88BlueGT
88BlueGT's Avatar
I forgot the brand name but it was a regular liquid filled pressure gauge... a local speed shop should have one... or summit
88BlueGT is offline
Old 09-22-2006, 01:28 PM
jzgt
jzgt's Avatar
You don't have to -- you can still set it with a standard service type (connect, set, disconnect) or you could get an Autometer mechanical the 3 feet of braided line and hook it up to the regulator port & mount it on the cowl. Do not mount a mechanical fuel pressure gauge inside the car unless you use an isolator (metal cylinder with a diaphram and antifreeze in the other side of the line leading into the passenger compartment). You can also get electric but they're much more expensive. You can mount a mechanical on the cowl using a mounting cup or a product like the Cowl Gauge Concepts cowl panel (one gauge panel).
Also, I've used a Paxton FPR on my car for 6 years without any issues.
- Jeff
jzgt is offline
7upedition
7upedition's Avatar
Aeromotive has some nice ones adjustable from 30-70psi, EFI models, and different mounting locations. Also for a guage Aeromotive makes a nice 0-100psi guage 1 1/2" diameter with white face for only $25, you can get an autometer but its gonna be $$$. Check them out @ JEGS.com Good Luck and good choice on the fuel pump!
7upedition is offline
Old 09-22-2006, 01:50 PM
grumpyphillips
Thank you everyone who gave suggestions. I will do some more searching today and now I have a good basis to start with.
Meystang
09-25-2015 04:05 PM
StalkerGT
09-25-2015 02:41 PM
SteelerNation82
09-16-2015 07:11 AM
Wombatnation
09-13-2015 09:16 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Quick Reply: Fuel Pressure Regulator Suggestions
