edelbrock rpm 210cc ??????????
RE: edelbrock rpm 210cc ??????????
What are you planning on using it for? That setup is more for drag racing, because of the huge ports on the heads and rpm2 intake. Your low end will really suffer, most edelbrocks street heads are 170cc intake.
probly will go with 165cc rpm heads ,and rpm 2 intake, custom cam 4 the juice ,70mm tb ,75mm maf 4 ,24lb injectors,410gears,msd ignition,pro 5.0 shifter ,125shot of juice
