SEA FOAM? CANT FIND IN SEARCH
RE: SEA FOAM? CANT FIND IN SEARCH
NO NO NO DO NOT JUST DUNK THE LINE IN THE BOTTLE!!!!!
Ever heard of Hydrolocking a motor? That will happen if you do that.
You take the bottle of Seafoam and SLOWLY tip it towards the vacuum line that your holding in your other hand. The vacuum through the brake booster line will sufficiently suck the seafoam right out of the can, if close enough. Your supposed to use 1/2 of the $4 bottle through the booster, done properly half of that can should take 10-15 minutes to completely and SAFELY do this. I repeat...
DO NOT DUMP IT RIGHT IN.
jessicarabbit
09-25-2015 12:41 PM
