351w heads on 5.0??
RE: 351w heads on 5.0??
plz i had a set of factory70 351w heads.. with194/16 valves back cut for flow and still flowed around 198 on intake side///my edelbrock rpms stock form flowed224/178 if i remember right on a flow bench.. the ford 351w heads that were 69/70 had like a 184/154 valves..and didnt flow no 198 from factory..and ported they ran about 220s or so...with bigger valves..edelbrocks i have 224 and when was ported i flow 276 intake side..but for ford 351w heads in those years they are good..buy the timeya pay to have done up good///a set of windsor jrs/srs are just as cheap...
gt40/gt40p are a better buy they flow more and are easier to find for the same price also the 351w heads have to be milled because the combustion chambers are alot larger
my setup,
but some work done to them bronze guides, hardened seats, enlarged bowls, chopped .010 1.94 intake, 1.6 exhaust valves, stage 3 extreme port and polish job, .600 lift springs, spring coils to prevent any binding, snug fit umbrella's to reduce oil consumtion, head bolt bushings.
takes 2weeks after dropping em off to the machinist
292 rwhp 5,420 rpm after my old tune.
