HEAD GASKETS-MLS WITH BLOWER
Time to decide what head gaskets I am running.....heard good things about the Multi Layer Steel gaskets from Fel Pro...they are like $85 a piece...anyone running them or any other suggestions
RE: HEAD GASKETS-MLS WITH BLOWER
Lots of guys in the Dallas area are running the regular felpro 9333-pt1's on boosted stangs. Several of the guys have tried others and gone back to those b/c they work the best. I've heard great things about cometic head gaskets, but $$$$$$$$$.
I will have to see if those will work....I am using the new Ford Racing Boss 4 bolt block and the gasket is not the same as a stock 5.0 block....cooling areas are different....
The Ford block is actually like 600 cheaper and supposed to be stronger than a Dart...The Ford has screw in Freeze Plugs and supposedly the cast is stronger than Dart....I will let you know..if I ever get it running again...April is the goal.
