holley systemax kit or trick flow????
Old 02-13-2007, 11:23 PM
LTnone
LTnone's Avatar
Default RE: holley systemax kit or trick flow????
Heck if you're pulling the engine and apparently have plenty of $$$ to spend, just toss a 351 in there. Much better potential/power handling capabilities
LTnone is offline
Old 02-13-2007, 11:35 PM
brenstang
brenstang's Avatar
im getting ready to sell my dirt bike and snowmobile, and have tax return money.. So ill have around $4000 to work with. ive been looking at the 331 stroker kit from dss.. But im just trying to do as much research right now as i can
brenstang is offline
Old 02-13-2007, 11:41 PM
89gtsleeper
89gtsleeper's Avatar
I would mix and match. Basically, I would do the systemax intake, especially if you're going to have a power adder down the road. Get the twisted wedge heads with the 2.02/1.60 valves and upgraded springs good for .600" lift. Slap in an FMS X303 cam, or a trickflow stage 2 cam. If you've got stock pistons, you'll have to get thme notched for clearance, but I think you said you were getting new stuff anyway right??? The heads/cam/intake I suggested will be approx the same price as the two kits you mentioned... maybe cheaper.
89gtsleeper is offline
Old 02-14-2007, 12:44 AM
Goosepoop302
Goosepoop302's Avatar
LTone what do you run or what kinda numbers you pushin?
Goosepoop302 is offline
Old 02-14-2007, 01:20 AM
phalcone
phalcone's Avatar
I use the holley intake , & trick flow heads. If you want to spend some money & get a real good engine check out tandlengines.com I got an awesome 347 from them. They are a real engine developement plant. They have been featured in muscle mustang and fast ford several times.. i know this sounds like an add.. but i love my engine.
phalcone is offline
Old 02-14-2007, 01:28 AM
LTnone
LTnone's Avatar
ORIGINAL: Goosepoop302
Won't have numbers/times until spring, but I'm guessing it should be 300rwhp, maybe a few more. I've got some other small stuff that will help out, but we'll see. The place I'm getting it tuned uses a Mustang dyno that will actually predict 1/4 performance w/in .2sec and 1-2mph accuracy. It will be interesting to see what I can do compared to what the car can do. And it's LTnone, because my ford has no LT's Cheesy, I know, but ya gotta do what ya gotta do
LTnone is offline
Old 02-14-2007, 01:32 AM
94StinkinLincoln
94StinkinLincoln's Avatar
performer rpm 2, afr 185's especially if ur boosting, and custom cam. im going NA with that stuff and a 331 kit from eagle.
94StinkinLincoln is offline
Old 02-14-2007, 01:42 AM
90Lxstanger
90Lxstanger's Avatar
Yeah i read where AFR 165's added 100bhp on and stock block, then 23 more hp with 1.7 roller rockers on it
90Lxstanger is offline
jwog666
12-27-2021 08:09 PM
Lethaldosage423
10-19-2015 12:12 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: holley systemax kit or trick flow????
