Explorer GT40p Heads?
im looking to replace my stock E7 heads with a set of GT40p exploder heads. is this a quick swap over or do i need other mods in order for this to work properly? new cam/pushrods? i also want to remove the emissions tubing that has been capped off b/c it's leaking a little. do they make a cap to cover the hole in the heads? or should i just weld it shut?
RE: Explorer GT40p Heads?
the gt40p does not have the hole in the back of the head for the air tube. they say you will nead a new header becuase the spark plug hole is different than the stock heads I just put a set on mine and got a gt40p headers off ebay for 139 bucks good luck
