having problems setting timing
my timing is now at about 7 degrees and its still knocking a bit under heavy load. i just put in some 89 octane, and i guess i'll find out if that helped or not.
i'm sure i'm doing everything right and yes i removed the spout plug.
thanks everyone.
thanks everyone.
This may sound a little off, but have you tried spraying a small amount of water into your intake while it is running. If you constantly are running high octane gas and have stepped down to regular octane you may have a lot of carbon build up on your valves. Spraying a small amount of water will help clean your motor. I have a water injection kit on mine and the last time I pulled my heads off they were really clean.
KEM Motorworks
Aug 14, 2015 10:13 PM
