Help with Gauges
RE: Help with Gauges
well off times, if your car is from the east coast... the circut board gets corrosion and eats away at the ribbon wire material, might just be whats goin on.... is there alot of rust on the car?.......... sounds like what ya gotta do is pull that cluster out and examine it
ORIGINAL: luckypballer
The dimmer switch works, bulbs are fine, and the wiring is correctly put in. What elese could it be?
broken wire going to dash cluster lights
broken circuit on printed circuit board on dash cluster
wiring harnesses to dash cluster not plugged in correctly or corroded contacts in plugs
bad ground connection from dash cluster circuit
Thx for all the help guys, but today I smashed into an old lady that cut me off, looks like it will be totaled. I had my stang all of 2 days.
By the way not my fault, even though i was going 60 in a 40, she still got a ticket and all the blame
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
