AOD Torque Converter Question
Old 05-31-2007, 11:44 AM
ncascademtns
ncascademtns's Avatar
Default AOD Torque Converter Question
I have about 200 miles on my new motor. A couple of weeks ago I started leaking tranny fluid out of the front seal so I dropped the tranny and replaced it. The leaking stopped but I developed a knocking noise under the hood. Neighbor says it's the engine which I don't want to believe. Might or might not be the tranny.
Somebody here at work says that if you unbolt the torque converter from the flywheel, you have enough play to push it back so that you can start the motor without engaging the tranny and possibly rule out one or the other. Well, I unbolted it and tried to push it back and it would not go. Is this true or false?
I would like to get to the root of the problem and get my car back on the road. Thanks.
ncascademtns is offline
Old 05-31-2007, 12:11 PM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: AOD Torque Converter Question
to you really wanna take the chance of your tq converter coming into contact with your flexplate?
AdderMk2 is offline
Old 05-31-2007, 01:23 PM
luckythirteen13
luckythirteen13's Avatar
sounds like a dissaster waiting to happen but im sure many of retarded mechanics have done it.
luckythirteen13 is offline
Old 05-31-2007, 10:47 PM
92hatchLX
92hatchLX's Avatar
Your flexplate is behind your torque converter, I wouldn't attempt it, that guy sounds like an idiot.
92hatchLX is offline
Tivo304
08-28-2023 12:19 PM
spamedic
09-09-2015 12:15 AM
v8sn95
09-07-2015 10:17 AM
Quick Reply: AOD Torque Converter Question
