Swapping Motor Mounts
Old 07-03-2007, 10:59 PM
92 50's Avatar
Default Swapping Motor Mounts
I can't get the two bolts to the block on each side loosened... I'm using a 3/8" drive ratchet with an extension and a 16mm socket. I probably should be using a breaker bar and 1/2" drive socket but don't want to spend $30 for those three things...
Let me know how you got yours off!
Thx!
92 50 is offline
Old 07-03-2007, 11:40 PM
88stangaruu
88stangaruu's Avatar
Default RE: Swapping Motor Mounts
you need to be part contorshionist and have thick skin on your knuckles.
Bascially intuision, soak them down in some penetrating oil while you drink a beer/smoke a cig. then go at it. Thats all i can tell you.
As for the tools, you really need the right tools, that always helps, see if a buddy or something has them and borrow them or something.
88stangaruu is offline
Old 07-03-2007, 11:53 PM
CantStopTheFox...
CantStopTheFox...'s Avatar
I used a breaker bar and 1/2" drive
CantStopTheFox... is offline
Old 07-04-2007, 12:05 AM
92dropgt
92dropgt's Avatar
just spend the money and get the tools, you will use them later on in life. i guarentee it.
92dropgt is offline
11-18-2015 01:34 PM
LivingInThePast
09-16-2015 12:20 PM
EASTIDEE123
09-14-2015 03:52 PM
jaiidutch
09-14-2015 10:29 AM
09-10-2015 07:23 PM
Quick Reply: Swapping Motor Mounts
