Water pump sealing tips?
Old Aug 2, 2007 | 02:28 PM
  #31
mattdel's Avatar
mattdel
Default RE: Water pump sealing tips?
i take a close look at every part i install on anything, just because i've dealt with crap like this too much. after about 5 defective parts installed on customer vehicles, you start lookin over everything.
Old Aug 2, 2007 | 02:55 PM
  #32
VigCS's Avatar
VigCS
Yeah....lesson learned I guess. ****.
Old Aug 2, 2007 | 02:59 PM
  #33
CantStopTheFox...'s Avatar
CantStopTheFox...
ORIGINAL: ZachW04Stang
At work I use air craft glue from the parts store. Its really tachy and seals pretty good. When you buy a new water pump make sure you pull the backing plate off and put some on both sides of that gasket too. It will never leak. Also when bolting down a water pump I always try to make a cross of the bolts tightening them down so nothing warps.
I used the same....no leaks
Old Aug 2, 2007 | 03:01 PM
  #34
VigCS's Avatar
VigCS
ORIGINAL: CantStopTheFox...
That problem is over and done with...encountered a new one...read up a few posts.
Old Aug 2, 2007 | 04:36 PM
  #35
VigCS's Avatar
VigCS
Well, *knock on wood*, my fix seems to have worked. Silicone and overly tightened clamps ftw.
Old Aug 2, 2007 | 04:37 PM
  #36
mattdel's Avatar
mattdel
good. as long as you didn't create any splits in the hose by clamping it too tight, you should be good to go.
Old Aug 2, 2007 | 04:49 PM
  #37
VigCS's Avatar
VigCS
There aren't any splits. The hose is brand new. I'm excited . Now to tackle my exhaust leak.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
