Intake removal?
Old 02-04-2005, 07:04 PM
Mustang88LXKid
Mustang88LXKid's Avatar
Default RE: Intake removal?
the only hard part is all the stupid lines under the intake, but besides that its an easy removal!
Mustang88LXKid is offline
Old 02-04-2005, 11:48 PM
90Mustangfan
I ♥ Acer
90Mustangfan's Avatar
hey while the intake is off you might consider getting a intake spacer, they help remove heat to the upper intake, there like 30 bux why not it could only help
90Mustangfan is offline
Old 02-04-2005, 11:53 PM
Mustangous
Mustangous's Avatar
ORIGINAL: mustang8719
That is what I do I just don't like doing things twice.I always buy new gaskets thats just the way I was taught.
Well if you have a aftermarket intake gaskets arent always available immediatly and also when you rip with the upper off and on for different reasons and if dan
ORIGINAL: Dan89lx
yeah, its easy, ive done it about 8 million times.
bought 8 million sets of gaskets, it gets expensive.......
Mustangous is offline
Old 02-04-2005, 11:56 PM
fast83gt
fast83gt's Avatar
Yet another disadvantage of fuel injection..
Actually if you guys want to laugh at me I was thinking about my car (carburated of course), and thinking this guy is crazy thinking he has to remove his intake to change rockers.
fast83gt is offline
Old 02-05-2005, 12:06 AM
Mustangous
Mustangous's Avatar
ORIGINAL: fast83gt
yeah thats a pain if you got solid lifters and needs to be adjusted often.
Old 02-05-2005, 12:13 AM
1994gtchris
1994gtchris's Avatar
do those 1.7s make a big difference can you get those when your kinda stock?is there enuff valve clearence?
1994gtchris is offline
Old 02-05-2005, 12:20 AM
fast83gt
fast83gt's Avatar
To determine the change in lift when changing rocker arm ratios, divide the lift of the cam by the original rocker ratio (which gives you the lobe lift), then multiply this number by the new rocker ratio. For example, the stock Mustang 5.0L HO cam has .444†at the valve. Divide this number by the stock rocker ratio of 1.6 to get the lobe lift, .2775†and multiply by the new rocker ratio 1.72, to get the new lift of .477â€.
This is a cut and paste from another site
fast83gt is offline
Old 02-05-2005, 01:55 AM
sup95cobra
sup95cobra's Avatar
ORIGINAL: 90Mustangfan
Just make sure you have clearance under your hood before you buy a spacer
sup95cobra is offline
Granatelli Sales
01-20-2020 12:34 AM
Vrooom
02-21-2016 05:25 PM
04stangman
09-17-2015 01:45 PM
wawagner82
09-13-2015 09:02 AM
vintageaion
09-08-2015 10:45 AM
Quick Reply: Intake removal?
