having trouble reading schematic
http://www.veryuseful.com/mustang/te...nSwitchWiring.
ok so i found this diagram surfing the net..onyl thing is im not too too sure how to read it correctly.does anybody know which color wire is the ignition on wire?i think its the red/green wire but im not sure..also would anybody know which color wire on the headlight switch is 12v power so i can tap in for lights on my gauges???car is an 88gt..thanks guys
Yep....Red/Lt Green....for the gauges, you want to splice to the Lt Blue/Red out of the dimmer switch shown below..... you'll be able to dim the gauges as well.......
if you are tapping into the wires for gauge lights u will use the dimmer. on the back of my dimmer i'm pretty sure i used the brown wire. then your gauges will dim with the dash lights. you can find it easily with a multimeter, that's how i found mine.
mungodrums
Sep 28, 2015 10:54 PM
Sep 25, 2015 09:06 AM
