Low RPM Vibration/clunk on 87 GT MTX
Hey guys,
I am new to the forum and I have a question for all you manual transmission GT owners.
I am considering getting a 87 GT from a local. He wants $7000 for it, but he did put a lot of work into it.
I took it for a test drive and noticed at low RPM (and low speeds) between 1500-2000 RPM in a high gear there was a vibration/clunk that seemed to be coming from the rear every once in a while if i were to slightly depress the gas. The owner didn't know what is was and said that all Mustangs he drove had that feeling. He simply said he drove in 2nd or 3rd @ 3000 RPM rather than 4rd or 5th @ 1700 RPM around 40-45 MPH.
I have a tendency to drive in high gears (5th @ 30 MPH) if I am not trying to get anywhere fast and trying to conserve fuel (in my Mazda MX6 V6). Is that a bad habit in MTX Mustangs?
Here are the mods on that car that are relevent:
GT40 - 1000 miles
Racing tranny? lower 1st gear - 1000 miles
King Cobra clutch
New tranny mounts
Aluminum driveshaft
Control arms
3.73 cobra rear end
Any thoughts on what this vibration/clunk could be? I would be considering an aluminum flywheel if I were to get the car.
Thanks
Tom
GT40 - 1000 miles
King Cobra clutch
New tranny mounts
Aluminum driveshaft
Control arms
3.73 cobra rear end
Thanks
Tom
RE: Low RPM Vibration/clunk on 87 GT MTX
Oh that's okay, sorry bout the problem I have an automatic... Check U-joints though especially the rear one, there should be no play there if you move the drive shaft around.
ORIGINAL: 1991_5.0_Convertible
Also check the sway bar mountings and the shocks.
Also find out if the control arms have Urethane bushings in them.That might not be the problem but might transfer some vibration into the body.
ORIGINAL: 86HOGT
My u0joint in the rear is a bit loose and vibrates like a **** at higher speeds. Honestly, that's not that much into the car or anything special for $7000.
I will try to list all the modifications:
87 GT Convertible garage kept)
Cobra motor GT40 heads - 1000 miles
Somesort of aftermarket transmission 1000 miles (feels solid)
aluminum driveshaft
carbon fiber ram air hood - functional
CAI
shorty headers
larger alternator
underdrive pulleys
cobra posi trac rear 3.73 with rear disks
offroad H pipes
92 interior (seat belts don't seem to line up)
Viper alarm
crossdrilled rotors - front
lowering springs - front
coilovers - rear
tokico shocks and struts
17x9 cobra rims
subframe connectors
three point front strut tower brace
removed AC
carbon fiber tail lights
projector headlights
aftermarket rear spoiler
custom interior and trunk interior for 1-12 sub box (doesn't look all that nice)
dynomatted trunk
4 point bolton roll bar
king cobra clutch
larger MAF
larger throttle body
Paint looks good but not perfect
Top looks good but will eventually need to be replaced
200 MPH white face guages
190 warbro fuel pump
adjustable FPR
24lb injectors
