water pump pulley wobbling
Old 03-02-2009, 03:29 PM
9165pt0
9165pt0's Avatar
Default water pump pulley wobbling
installed some underdrive pulleys about a month ago and now i notice that the water pump pulley is wobbling. i took off pulley and put it back on and aligned everything and it seemed to go away. but today its wobbling again...? Could it just be the pulley, or is it the bearings on the pump?
9165pt0 is offline
Old 03-02-2009, 03:52 PM
AdderMk2
Banned
AdderMk2's Avatar
take the belt off and wiggle the shaft... if there is play. you need a pump
AdderMk2 is offline
Old 03-02-2009, 03:54 PM
Portmaster
Portmaster's Avatar
If the pulley isn't cracked at the mounting holes the water pump is bad
Portmaster is offline
Old 03-02-2009, 07:44 PM
9165pt0
9165pt0's Avatar
ok im going to take it off right now, (as well as the steering pump as in the other post). could it be the fan? its wobbling as well?
9165pt0 is offline
Old 03-02-2009, 08:43 PM
5.0 85 GT
5.0 85 GT's Avatar
the fan runs off the same pulley, so its forced to wobble with it...make sur eits aligned again, and continue to see if the bolts stay tight after u drive it for a while...
5.0 85 GT is offline
Old 03-02-2009, 09:56 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
fan is bolted to the pump shaft base so check the pump = most likely bad
mjr46 is offline
Old 03-03-2009, 01:10 AM
9165pt0
9165pt0's Avatar
checked the pump shaft and pulley and both were fine. but the fan clutch seemed to be locking up. so i put the fan out of another mustang and it works fine. no more wobble.
9165pt0 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
jwog666
12-27-2021 08:09 PM
jerrytubes
10-23-2015 12:11 PM
Bokeo
10-10-2015 08:28 PM
KingRando
10-02-2015 08:06 AM
Quick Reply: water pump pulley wobbling
