huge problem need help on 4cyl notch to 5.0 conversion
Old 03-06-2009, 12:17 AM
kennebellgt
kennebellgt's Avatar
Default huge problem need help on 4cyl notch to 5.0 conversion
I am doing a conversion with a 89 4 cyl. notchback, i have a wrecked 94 5.0 and i ran into a big problem, the dash harness is different and so is the harness that is behind the fender on the driver side firewall, how can i get the sn95 harness to work im stuck until i find this out, please help thanks guys
kennebellgt is offline
Old 03-06-2009, 07:50 AM
Portmaster
Portmaster's Avatar
Put the entire SN-95 dash in the Fox. It looks really sweet
Portmaster is offline
Old 03-06-2009, 07:55 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Honestly, I'd use the fox harness/set up =less work involved.
mjr46 is offline
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Yes, yes it does.. Just be sure to do your research first. the dash does require trimming to get it to fit correctly. Good luck if you do. I plan on dropping it into one of my cars sometime in the future.
projectresto83 is offline
Old 03-06-2009, 09:00 AM
Redneck1465
Redneck1465's Avatar
Your better off putting in the fox body stuff its so much easier because its baisically plug and play.
Redneck1465 is offline
Old 03-08-2009, 04:56 AM
kennebellgt
what year do i need 89? or 88-93? i think they may be different in those years
Tivo304
08-28-2023 12:19 PM
articman
06-21-2018 11:45 PM
11-10-2015 11:39 AM
5.0 kevo
09-03-2015 06:24 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: huge problem need help on 4cyl notch to 5.0 conversion
