You need to match the flexplate to the balance of the engine with Eagle FORGED CRANK it should be internal balance and therefore neither. It would use a neutral balance Flexplate. IF you have the cast steel crank it would be 28oz. You need to check with your engine builder, he should have balanced the rotating assembly with the Flexplate you intended to use.
