BBK SSI-R!!!
if so, thats more then likely the problem. Common problem.
the car i posted up has a slight whiney whistle too. very slight though, can only hear it with the hood open, but it is an obviously "whistling" noise. most often times due to sharp edges after assembly or casting. smoothing these issues should solve the problems. if those dont solve your issue, an 1/8" hole in the butterfly will fix it.
Now all you have to do is take the rest of your money, throw it on your lawn, and light it on fire. Far better use of funds.
There are two intakes that make power on 5.0-s. The trick flow track heat, or the edelbrock performer. Bench tests will confirm this, my car loved the track heat too.
The SSi isnt a whole pile better than stock, just a lot more expensive.
Luke9222
10-22-2015 11:55 PM
JDWalton
09-24-2015 08:47 PM
