under drive pulley kit
i have under drive pulleys on my car, but I can't remember what size belt it is right now. Just take a string or something similar and wrap it around in the correct belt routing. Then just go to your local auto parts store and find whichever belt is the most close to what you need. That is what I did.
it "should" be about 1" shorter than stock
if you can read your existing belt number just do this...
belt = this (letters all vary on brand, but numbers are the same)
gates for instance... ko60695
ko=nothing
6=6 ribs
0=space(blank..nothing...separation)
695 = 69 1/2" total length
so if you wanted a 1" shorter than this belt... you'd need a ko60595
the best thing to do is get it the parts store... or just go there but this takes longer, try the belt that are 1" longer 1 1/2" longer and 2" longer
and the belt number i gave was what i used to run to bypass smog and PS with an AC car and pulleys
** if the belt you find is in range... but on the lower end of the range, get 1/2" shorter... they tend to stretch a little after driving, or the adjuster finally takes all the slack off, and you'll get out of range... will still work... but it'll stretch out quiker
ko=nothing
6=6 ribs
Soldier GT
08-12-2015 03:46 PM
