Favorite / Most popular Lowering Springs
RE: Favorite / Most popular Lowering Springs
Yeah i tihnk im going with the Eibach Pro kit i can get it for 220 shipped at some site ... Is it hard to do it yourself i never did that before so i dont know .. thx
ORIGINAL: Mustang5.0_GT
The most popular is eibach and if your dont plan on turning your car into a corner carver then all the other springs will be just more expensive and do the same thing you are looking for...a more agressive stance.
If you do want a corner carver then look into getting the proper spring weight along with the matching struts/shocks.
I'm saving for H&R springs
just go to your local auto parts store and buy the spring compressors there. thats what i did, the compressors were pretty cheap and you only need to use them for the front. the rear is easy and you dont even need them. just jack up the car put on jack stands. jack up the rear diff. a little bit, undo the shocks and lower it and there you go. you might have to pull down the rear a little bit but its easy. i think it took me about 2 hours to do all 4 of mine. just take your time and make sure you get the spring compressors on there right. they can be a little tricky. good luck
mungodrums
09-28-2015 10:54 PM
mungodrums
Suspension
09-24-2015 10:12 PM
