Timing - Can't see marks the balancer - Any ideas?
Hey guys... Got a nice deal on a timing light, so I hooked it up, but I should have known.... My 87 is in great shape for it's age, but I cannot see any marks at all on the harmonic balancer. They are just not visible as the balancer is a bit rusty from age. Short of installing a new balancer, are there any trick to making them visible, or getting the timing checked or bumped up? Sorry for the silly question, but I'm sure others saw this before too on stock 20 year + Mustangs..... Any suggestions? Thanks.
Be sure to unplug the spout before setting the timing or your just waisting your time.If you are sure what i'm talking about there is a clip of wires that plugs into the front of the distributor.There are a couple of black wires that go off that has a small clip on the end. Unplug that clip to set timing .For years I thought I was setting doing that when setting my timing but I was removing the big clip that goes to distributor .Wrong
hey, thanks for the advice guys. Went under the car and cleaned it off. Was able to find the 0 and 10 and 20 degree marks. It was late at night, so I did not adjust the timing yet, but was able to check it with the spout out. Looks like it was set a the factory and never, ever adjusted. It seems to be at 8 degrees , so very conservative. I will try to get it to 10-12 range and see if it likes it. Don't really want to start putting 93 in her all the time, but 89 might do with a slight bump up. Might help with low end pick up a bit, but it runs quite nice and strong as it is now at 8. Never hurts to try something new, right? Might like 10-12 even more...
Urambo Tauro
08-27-2015 10:53 AM
