Mustang feels like a V-Tech???
Old 10-14-2011, 08:27 AM
OiDALE
OiDALE's Avatar
VERY NICE READ...WELL THAT MAKES A BIT MORE SENSE, THANKS.
OiDALE is offline
Old 10-17-2011, 03:05 AM
Dj_Seph
Dj_Seph's Avatar
It's a broken baffle in the tank. I had the same problem. There's a little rectangular box in the tank that sometimes breaks lose and causes problems. Just replace.
Dj_Seph is offline
Old 10-17-2011, 08:05 AM
OiDALE
OiDALE's Avatar
Replace the whole tank? or can you just replace the baffle? where can I buy it and how is it done? thanks...
OiDALE is offline
Old 10-18-2011, 01:42 AM
Dj_Seph
Dj_Seph's Avatar
Replace the whole tank. Unless you want to cut the tank open and weld the baffle back...
Dj_Seph is offline
Old 10-18-2011, 09:29 AM
OiDALE
OiDALE's Avatar
If it is broken when I bring down the tank I would be able to here something by rocking the tank if theres anything loose? I will look into it when I replace my pump...
OiDALE is offline
Old 10-18-2011, 09:38 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
The baffle is right under the pump. You will notice it when you replace it
projectresto83 is offline
Old 10-21-2011, 08:17 PM
OiDALE
OiDALE's Avatar
Thats what I will do, As soon as I swap my intake I will throw in a 180. But for now I will set my fan at around 185. With a heat gun to measure the temp, where should I read the correct temp to set my fan to turn on? At the filler neck going into the lower intake or at the radiator right after the water inlet?
OiDALE is offline
Old 10-22-2011, 09:22 AM
mattdel
mattdel's Avatar
At the thermo housing, or filler neck as you called it.
mattdel is offline
Diode Dynamics
28
05-26-2022 12:02 PM
ShaneB26154
35
03-04-2021 04:05 AM
mweiland
08-16-2015 10:59 AM
ponyride00
08-12-2015 01:57 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: Mustang feels like a V-Tech???
