28 or 31 Spline
28 or 31 Spline
I am replacing everything in my rearend. Posi, Axles, Gears, the works. What spline should I go with? Also what all would I need for this project? New seals and bearing, gasket, what else?
Thanks for the help.
RE: 28 or 31 Spline
i believe they are already 31spline in 86-93 8.8's....???
i just did my whole rearend, got the whole deal from strange, 31spline and they include c-clip eliminators and what not for 320ish i think it was. dont forget about c-clip elims. especially if your doing some sort of locker or spool.
RE: 28 or 31 Spline
i was looking at stranges catalog which i have right in front of me and it says for the four lug with the c-clip eliminator package its for drum brakes, and i plan on going to 4 lug four wheel disc. Help??
RE: 28 or 31 Spline
I am replacing everything in my rearend, because my bearing went out and my mustang is my only transportation so im sure that the axles and everything else is messed up, also everything is 20 years old as its an 85.
RE: 28 or 31 Spline
ORIGINAL: marine_2003
RE: 28 or 31 Spline
I would also scrounge the junk yards for 87 and up pick up trucks and look for the 8.8 locking carrier. It is 31 spline, has the 7/8" diff pin instead of the 3/4" pin and uses the same track loc rebuild kit as a stock 5.0 8.8" rear diff. It is the cheap way to get the FRPP 8.8 31 spline heavy duty track loc unit. Plus junk yard hunting is fun. Pack a lunch and have at it!
Boostaddict
Lethal Performance
08-13-2015 01:57 PM
