Cleaning a Throttle Body
Just wondering what tihngs i can use to clean up my TB , Ouside, if any1 has done this b4 .... And 1 of the screws off on the TPS is all the way out .... I should check that right?
RE: Cleaning a Throttle Body
don't spray anything on the throttle body unless you have the coatin safe...There a plastic coatin in the throttle body, if thats gets messed up the car wont run right.....3M makes a throttle body cleaner which is safe to use..
I get the bg stuff for 12 bucks. It includes the throttle cleaner, gas cleaner, and fuel injector cleaner. The difference between the gas cleaner and fuel injector is that you have to hook the fuel injectors up to a special pressure wash machine. It's a dealer item.
I have to adjust my TPS but i can only get to 1 screw, theres like a plug the way of the other 1 ... Should i take that sensor off or sometihng to adjust it ... Also can i use my Stock Sensors and everytihng?
