Stupid Cams....
Old Oct 6, 2008 | 01:56 PM
  #21
84gtcustom's Avatar
84gtcustom
If I did a 331 with all the stuff i'm doing, could I make 400 RWHP with a cam from jay? he was talking around 300-310rwhp with my 302 setup and a roller cam.
Old Oct 6, 2008 | 06:05 PM
  #22
83ttopgt's Avatar
83ttopgt
what would be wrong with running a flat tappet cam? My dads 70 mustang has a nasty 302 with a flat tappet and that thing is retarded fast (not sure of motor specs, my uncle built the motor when I was too young to understand what any of it was)
Old Oct 6, 2008 | 07:03 PM
  #23
84gtcustom's Avatar
84gtcustom
the heads I have came with AFM hi rev springs - to stiff for a flat tappet. so I would have to change, downgrade, the BRAND NEW setup to stick with flat tappet. If I go with a conversion or a roller block, I can use a roller cam and get a few more rpm's and 2-3mpg more!!
Old Oct 6, 2008 | 07:49 PM
  #24
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
with the removal of zddp from oil it is now ever so important to run a replacement additive when breaking in flat tappet cams, where as roller cams need not.....and roller cams rev quicker = less friction and wear on valvetrain parts
Old Oct 6, 2008 | 08:39 PM
  #25
Joel5.0's Avatar
Joel5.0
AFR 165's = a 302/310 setup, strokers require a better set of lungs. Since you have a non-roller block, another alternative you could check is a TLSR (Tight Lash Solid Roller) cam from Jay. Will you have to upgrade the springs?.... yep, yet it'll be worth it due to the HR link lifters vs SR link lifters cost difference..... - OR - you could sell those AFR 165's and upgrade to a TFS 190's "fast as cast" + custom cam package from Jay........ correct springs for the TLSR cam included at no extra cost for either set of heads. Just a thought. BTW.... total valve lift has nothing to do with possible PtV issues.
Old Oct 7, 2008 | 12:43 AM
  #26
84gtcustom's Avatar
84gtcustom
if thisis the same as a reduced circle base cam Jay dont do them anymore
what is wrong with my AFM springs?
what is the difference? standard vs roller conversion lifters?
I understand that now
thanks for your input
Old Oct 7, 2008 | 06:49 AM
  #27
mjr46's Avatar
mjr46
height of the roller lifter is different and they have link bars to hold them in the proper position so roller rides true on cam lobes
Old Oct 7, 2008 | 09:26 AM
  #28
Joel5.0's Avatar
Joel5.0
Nope... solid roller cam, standard base circle, Jay does a lot of those.
Not enough pressure for the more aggressive lobes in a TLSR cam, that is something that is known after the cam is designed though + it's not only a "spring good to .xxx" lift" spec, valve closed/opened pressure and pressure rate is more important.
Like MJ said, the SR linked lifters height is compatible with a non-roller block and less expensive than the HR linked lifters you need to stay away from a smal base circle HR cam.
Old Oct 8, 2008 | 09:53 AM
  #29
84gtcustom's Avatar
84gtcustom
joel5.0
I guess what I said is what is HR & SR. I dont know these terms.
how do you know wich springs I am talking about? AFM has several.
Old Oct 8, 2008 | 10:14 AM
  #30
Joel5.0's Avatar
Joel5.0
joel5.0
HR = Hydraulic Roller
SR = Solid Roller
I know, reason why you always "plan for the worse, and expect for the best"..... - OR - what if the AFM springs you have don't cut it for the cam design. BTW.... I only see 2 AFM valve spring choices
Tivo304
Aug 28, 2023 12:19 PM
ctgreddy
Oct 14, 2015 09:05 PM
vintageaion
Sep 8, 2015 10:45 AM
HorsePower99
Aug 26, 2015 11:29 PM
HorsePower99
Aug 26, 2015 08:32 PM
