throttle body whistle, and maf housing ?
Old Feb 7, 2009 | 09:03 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
MAKE SURE THERE ARE NO ROUGH CASTING EDGES ON IT, which can sometimes create a whistle, but I have seen the bbk ones do that
Old Feb 7, 2009 | 01:03 PM
saleenpride1986's Avatar
saleenpride1986
Originally Posted by 302army187
i dont mind it, and sence my girlfriend is so easy to entertain she giggles and carrys on everytime she hears it. "oooooh, the wistle! i heard it! did you!" "yeeees Becky, i heard it."
lol
HAHA WOW, That's awesome! I wish my gf would be as entertained as that. Mine just says, "SHUT UP STOP TALKING ABOUT THINGS IN YOUR CAR" and gets all pissy.
Old Feb 7, 2009 | 02:44 PM
FORD TOUGH's Avatar
FORD TOUGH
Try cleaning the idle air control valve.
Old Feb 7, 2009 | 07:42 PM
302army187's Avatar
302army187
wtf? time to find a new girlfriend!
i had to teach her where to check her freaking oil, but she still listen's to my babble about car's and ask's alot of questions.
Old Feb 7, 2009 | 11:52 PM
dudeboy's Avatar
dudeboy
Originally Posted by calfroper_06
yeah but it does get annoting. the throttle b osy itself is great, much better throttle respnse.
My sensor is calibrated for 19lbs, do you have to get a special housing for 19lbs too. i thought it was just the sensor but im not for sure?
The sensor is calibrated for the housing it's in, and the ecu it was designed for use with.
If there is a center post in the housing, and you can confirm that the ID is ~70mm....
and there is a part number on the sensor that starts with 'F2VF-'
and there is a '70' toward the end of the part number
and you are using a Fox ecu (other than a 93 cobra)
and you are running 19Lb injectors
then you should be ok....
Old Feb 8, 2009 | 12:04 PM
USMC1775's Avatar
USMC1775
+1, unless Im talking about HER car
Old Feb 8, 2009 | 07:06 PM
calfroper_06's Avatar
calfroper_06
cleaned it and switch another one out, still no change lol
umm ill have to check on the housing and sensor thanks for the info
Old Feb 8, 2009 | 07:14 PM
FORD TOUGH's Avatar
FORD TOUGH
Did you pull the little black cap off. My truck was making a "whooing" sound at a idle but as soon as you would give it a little gas it would stop and it was the IAC causing it.
Old Feb 8, 2009 | 07:18 PM
calfroper_06
what black cap?
Jb145700
Aug 21, 2022 06:37 AM
piotrek53
Oct 13, 2015 06:54 PM
JDWalton
Sep 24, 2015 08:47 PM
kachuy10
Sep 22, 2015 01:27 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
