Gears?
Old Apr 28, 2009 | 10:49 PM
  #21
1990lxhatch's Avatar
1990lxhatch
Originally Posted by domindart
1990lxhatch, do you think 3.55 is a good gear for a almost stock stang? I have 2.73 now I think. how do you check your gearing?
I want good highway, but I want good take off too. the car has pwer, it just needs something to give it better climb.
I had a friend who had 3.73 in his car and I think it was just, in my opinon, too much rev on the highway for what I want..
heres another question: does having a higher gear put more strain on the internals? I would guess it does put some more strain on the internals, but just how much, how high should I go on my car, a 111k car?
3.55 is the "have it all" gear. You get decent highway mileage with a torquey pull. 3.90's are ideal and I wish I'd have bought those instead. Most people find 3.73's ideal..... and the fact that every other bolt on mustang has them is a turn off for me. All my fellow fox buddies think the 4.10s make my car seem faster than theirs... in reality its a driver's race nearly every time.
In regard to stress....... engine speed isn't so much of a concern as the load the engine is under. A V8 motor turning 2000rpm in a 5000lb truck pulling a trailer is under much more stress than a V8 in a 3000lb unloaded car turning 4000rpm.
If you don't have aftermarket control arms AND torque box reinforcements I wouldn't recommend running any sort of drag compound tire and/or low ratio gears. You will beat on it, it will take a while to get used to launching it and the damage will be contained to your u-joints, control arm bushings, trans mount and torque boxes.
If you floor your car to redline with any sort of frequency (once a drive cycle or so) you shouldn't be concerned highway revs. They are relatively harmless. Hell, boat motors run 5k all day long.
Originally Posted by 1987notchback
ah NO i am in fifth and no i am not going by my speedo i am not an idiot, i had a car pace me to check and yes it was at 70 and it is a stock T-5 with 4:10's love your 4:10's all you want mine are goin in the trash thanks captain obvious anymore usless stuff you can tell me maybe you can explain to me how to check my oil next!
Nope. I really can't explain why the mathematics of dire diameter, final drive ratio and trans gear ratio don't apply in your alternate world. Perhaps it has something to do with the kid collecting the data..... hmmmm
Old Apr 28, 2009 | 11:32 PM
  #22
domindart's Avatar
domindart
so I should get better arms and tb reinforcements before I put gears on the car? hard to amagine, I have had friends that ran gears, I dont think they worried about these things
Old Apr 28, 2009 | 11:40 PM
  #23
94StinkinLincoln's Avatar
94StinkinLincoln
just b/c you dont worry about it, does not mean it can not be a problem.
Old Apr 29, 2009 | 12:17 AM
  #24
domindart's Avatar
domindart
right, well my nitrous running couldve done damage too but ..
can you just replace the bushings rather than the control arms in the rear, regarding this problem?
Old Apr 29, 2009 | 04:55 AM
  #25
83glx5.0's Avatar
83glx5.0
3900? Wiskey Tango Foxtrot are you even in 5th gear?
I'd suggest you are going MUCH faster than 70mph ..... but with the stock speedo gear and 4.10's you would normally read a faster than actual speed....... so I don't know what the hell you got going on there...Did someone install a speedo gear for 4.30's or 4.50's or something?
mmm, 4.10's with a 3 speed auto = 3500rpm doing about 60 ;P
Old Apr 29, 2009 | 06:56 AM
  #26
94StinkinLincoln
gears may not give you wheel hop, u might be ok.
if you do, replace the bushings. a better, but more expensive alternative is adjustable control arms.
Old Apr 29, 2009 | 08:43 AM
  #27
1990lxhatch
Haha. If this kid has a C6 confused with a T5 AND needs a pair of glasses...... you very well may be on to something.....
Old Apr 29, 2009 | 01:18 PM
  #28
1987notchback's Avatar
1987notchback
Default Haha
yeah its a t-5 alright, kid that cute i have not been called kid in about twenty years. as far as the "data collection" it is pretty simple. i am not on this forum to have people try to be online tough guys. i appreciate all the mature reply's oh yeah kid whiskey has an h in it. i wish i could meet you in person and see how far you got with your mouth.
Old Apr 29, 2009 | 01:52 PM
  #29
domindart's Avatar
domindart
I think Ill be okay with a 3.55 gear
Old Apr 29, 2009 | 02:12 PM
  #30
1990lxhatch
#1 Spelling error noted. My mistake. Your grammar could use a little work... but it seemed a bit immature to bring it up in a technical discussion.
#2 You got an attitude with me first. My original post was more of a *shock* that you were spinning almost a 1000RPMs more than everyone else with the same equipment.... not as directive to insult you. Again, perhaps I was misunderstood. I'm not trying to e-thug anyone.
#3 The more you post - the more mistaken, immature and hypocritical you make yourself out to be. An intelligent, reasonable and sensible person would likely be embarrassed by typing the bolded text above.
However, squashing this nonsense will be much more productive.... Lets figure out what's going on.
If in a mathematical perspective your engine speed doesn't match up your wheel speed given your gear ratio and trans ratios........
And in practice nobody else with the same trans, gears and tires is turning nearly 4 grand at 70mph.....
Is it more like you are
A) Living in the twilight zone
or
B) Mistaken about one of the variables involved in the problem
