i'm about to hangup i put the new comput in and still spittn 67 gonna bypass the nds hopefully and go from there anyone with any ideas please post why is this car runnin a lil lean and stallin at idle i need to pound / enjoy this car more b4 winter
You are guessing at a solution to solve the problem, rather than using the data the system is providing you. Code 67 = ECM detects transmission is not in neutral, reason why a KOER is not allowed to be ran.
Since your setup uses an automatic transmission, pin 30 of the ECM detects "in-neutral" state through the ground provided by the starter solenoid to frame contact, through the single post start voltage wire, through the transmission NSS switch, to the ECM connector. Do you have a separate push-button starter switch installed?... if not, you may have an open wire condition between the start wire at the solenoid and pin 30 at the ECM connector.
