Airing up a tire
Old Nov 24, 2009 | 01:52 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
Default Airing up a tire
Old Nov 24, 2009 | 02:49 AM
86 5.0L's Avatar
86 5.0L
http://www.youtube.com/watch?v=RwipxqtU35w
old trick we used off-roading
Old Nov 24, 2009 | 10:06 AM
USMC1775's Avatar
USMC1775
Yup thats the easiest way to get a wide wheel and thinner tire mounted. I had to do that with all 4 of my truck's 37's
Old Nov 24, 2009 | 02:07 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Originally Posted by TrimDrip
most of you probably know this but, thought I would share it anyway. I watched a guy air up a completely flat tire that would not seal with a bottle of starter fluid and a propane torch tonight.
We tried like hell to get this dry rotted tire to air up on a ten inch wheel and it would not hold air. So we pulled the stang up to the shop, he jacked it up and then he grabbed the ether. He started asking for a lighter and finally grabbed a propane torch. At this time, I grabbed a water hose. lol Anyway,he pushed the tire back and sprayed either on the inside of the rim, then sprayed a line of it on the concrete. Took the torch to the either on the ground and pop, the thing was fully aired up. It was the most redneckish thing I have ever seen but, it worked.
Oh course he got to telling me about a dune buggy story where a guy tried it twice and couldn't get it to hold, then sprayed to much and turned the buggy a flip. it was pretty funny.
Anyway, if your tire ever falls off the rim and won't seal, just grab the either. lol You may need to give it some air after this or the fire will burn up all the oxygen and it will go flat. There is a proper way to this but, the either is way cooler.
Seen it done about 25 years ago. Pretty dangerous in my opinion.
BTW, Your sig is too large!!! 500x250
Old Nov 24, 2009 | 04:21 PM
tohoopty's Avatar
tohoopty
im surprised you have never seen that before
Old Nov 24, 2009 | 04:46 PM
jscotty's Avatar
jscotty
Do you mean the process itself or is there additional danger after the tire has been inflated? I think that when I do this, I will remove the wheel from the car and then spray a very LONG line to keep a safe distance.
Old Nov 24, 2009 | 05:38 PM
Bubba 95SN's Avatar
Bubba 95SN
Use the same method to put tire back on rim of Bobcat. Machine that replaces 10 laborers.
Old Nov 25, 2009 | 08:35 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
pedalhappy
May 8, 2013 10:08 AM
jlcox25
Jun 24, 2008 03:44 PM
jcpower
Mar 17, 2008 07:33 PM
97modifiedmustangGT
20
Jan 14, 2007 04:16 AM
67Sally
Apr 15, 2006 01:21 AM
